K: CO liiga kõrge
K: CO liiga kõrge
Käisin ülevaatusel ja lubatud on 500 co-d aga mul 1900 millegagi. Et küsimus ongi selline, et kuidas seda normi saaks ajada. Annab sierral kuskil midagi kruttida, et bena palju peale ei saaks, v miskit.
Auto ise on ford sierra 2.0i 89a efi 74kw
Igasugune abi teretulnud, tänan
näita mootori pilti ja ütlen kas ikka on efitamar kirjutas:Mul 2,0i efi 74kw ja aasta kah 89.
Ja ma olen TÄIESTI kindel et mul on sissepritse, või sa tom väidad vastupidist ?:D
 sõbral oli ka 2.0 74 kw...monopritsega minu teada...kindlasti mitte efi ja kindlasti mitte tavaline karpa.
 sõbral oli ka 2.0 74 kw...monopritsega minu teada...kindlasti mitte efi ja kindlasti mitte tavaline karpa.powered by 2.0 Ohc
haynes ütleb mixture adjustment check kohta nii:
fuel injection 2,0l sohc
22 the idle mixture can be checked and if necessary adjusted as follows:
23 run the engine until it is at normal operating temperature.
24 stop the engine and connect a tachometer and an exhaust gas analyzer in accordance with the manufacturer's instructions.
25 start the engine and run it at 3000 rpm for 15 seconds, ensuring that all electrical loads (headlamps, heater blower etc.) are switched off, then allow the engine to idle and check the co content. note that co reading will initially rise, then fall and finally stabilize.
26 if adjustment is necessary, remove the tamper proof cap from the base of an airflow meter, and turn the mixture screw using a suitable Allen key to give specified co content (see illustration)
27 checking and adjustment should be completed within 30 seconds of the meter reading stabilising. if this has not been possible, run the engine at 300 rpm, for 15 seconds, then allow the engine to idle. re-check the co content and carry out further adjustment if necessary.
28 on completion of adjustment, stop the engine and disconnect the tachometer and exhaust gas analyser. fit a new tamperproof cap to the mixture screw.
EFI on kirjutatud peale, samasugune on moto nagu ametivennal.TOm kirjutas:näita mootori pilti ja ütlen kas ikka on efitamar kirjutas:Mul 2,0i efi 74kw ja aasta kah 89.
Ja ma olen TÄIESTI kindel et mul on sissepritse, või sa tom väidad vastupidist ?:Dsõbral oli ka 2.0 74 kw...monopritsega minu teada...kindlasti mitte efi ja kindlasti mitte tavaline karpa.
				karvaendel
- kasutaja
				karvaendel
- kasutaja
 kuid tahaks teada tõde
